If they are on opposed sides then 200mm. On the same side you can do what you like although in reality you’ll need some gap for the plumbing fittings. Part H of the building regs if you fancy a read
They would join the stack at 90 degrees to each other.
Build a plinth for the bath to sit on, much easier to get at the waste pipe then,dont forget to allow for a step unles youre quite tall, and looks cool as well.
it also gives you a bigger slope for the waste, so bath empties faster.
If it was a conventional bath then I would have put a plinth under the bath panel and raised the bath 50mm. It is an ‘L’ shaped shower bath though (we have a very small bathroom so have to have the shower over the bath). The bath panel would be difficult (although not impossible) to put a plinth underneath.
