Subzero seems bulletproof and the geometry's spot on. Nope! it has a ropey high BB.
if I wind the 66's down to 140 that tightens up the head angle and its perfect for twitchy singletrack.
But it would handle nicer in twichy singletrack with less travel. 140mm on the front of a hardtail is fine for no brain blatting through straightish rough sections but other than that less travel feels way nicer to me.
the stem is 50mm, would you suggest direct mount? that would ride awful!
Don't think ypou understand the term "direct mount" google it! I run a 40mm stem on my hardtail
why coils over air? the 66's can be tuned perfectly.
Air sprung is simply not comparible to coil (or as reliable)
Yep the EA70's are OS, whys that a bad thing?
I hate OS, there's no need unless you are running 750+ bars plus they are heavier and look shit!
the 823's are again bulletproof with no rear suspension it makes sense to have wide strong rims with big tyres no?
not really! like I said, they are overkill, 721s are strong enough and wide enough for any hardtail hero!
and how you can say tubless doesn't work for hard riding I'll never know!
Plain and simple, It doesn't! a tyre burping air is really not what you want hitting any corner flat out and it happens too frequently running sensible pressures (higher than needed with tubes).
as for the outlands I've not had a problem loosing my feet, I wear DC's that have a sole similar to 5:10's and the pins seem to grip fine.
Maybe, but for me, I hate 5:10 levels of foot grip and mainly use Etnies (occasionally Vans) and without a pin where I describe you have to jam your foot between the crank and pedal to stop it sliding off the edge of a pedal in rough loose drifty terrain.
so maybe I'll address the BB and related gubbins, ah ha! a plan emerges! tidy darts!
if you are happy with it, leave it alone!
