• This topic has 17 replies, 12 voices, and was last updated 8 years ago by Gunz.
Viewing 18 posts - 1 through 18 (of 18 total)
  • So the stem bolts in my Thomson stem are rounded?
  • teadrinker
    What do I do next? Please help 😀
    sharkattack
    That’s an excuse to get some ti replacements from Uberbike
    Stevet1
    Are all 4 rounded? if not you could try tightening the good ones up to relieve pressure on the rounded one(s).
    And don’t be so ham-fisted next time…
    scruff
    Can you tighten one up to loosen the other?
    trail_rat
    disposable slightly over size torx bit hammered in would be my first port of call.
    richmtb
    This
    Its stem bolts so they shouldn’t be massively tight in the first place.
    If they are 4mm hex bolts then T-25 torx should be tight enough to get them loose
    kerley
    I admittedly do over tighten stuff but the move to smaller bolts on Thomson stems must make this more likely and I have done exactly the same.
    I cut a slot into the head and then undid with a screwdriver
    Think the logic is that the head will round off before it is tight enough to do any damage to carbon steerer/bar.
    teadrinker
    I actually took this as an excuse to purchase a whole new bike. Not even joking, the headset came loose and I went to tighten it and then realised the stem bolts had rounded. My lbs is an evans so had a chat with them, came away unimpressed and just ordered a new bike. Now need to strip this one to sell it. In my defense though I was considering a change, I took this as a sign. I will have a look at the torx route and then if not I’ll try cutting into the bolt and using ascrewdriver, thanks all.
    trail_rat
    “I admittedly do over tighten stuff but the move to smaller bolts on Thomson stems must make this more likely and I have done exactly the same.
    Think the logic is that the head will round off before it is tight enough to do any damage to carbon steerer/bar.”
    NO NO NO AND NO
    if your rounding bolts your just being a hamfisted oaf. theres no other reason especially on a thomson.
    sharkattack
    Nice bike buying logic.
    If the stem in question is 50mm I’ll give you a tenner for it as is.
    onandon
    How the Christ do you round off bolts on a stem ? That’s just mental.
    kerley
    There is a reason on a Thomson due to the very small bolts they use (they are around 3mm aren’t they? That is very small for a stem bolt and many stems use 5mm bolts)
    I have NEVER rounded an allen bolt other then the new Thomson bolts so although I like things tight I know when to stop.
    Northwind
    If the question is “Aargh I’ve rounded off these bolts what do I do” the answer is basically never “get some extractors”. Because anyone that’s rounded off a stem bolt is going to end up with holes drilled everywhere but the bolt, and then with a snapped extractor in the bolt.
    Hammer in a torq, you probably only need to shift the bolts on one side this way, once they’re loose the rest should come more easily. Penetrating oil everywhere, obviously.
    Thomson, you can probably find a replacement faceplate easily because of their consumable faceplate bullshit, so if in doubt, I’d sacrifice that over the other bits but it shouldn’t be necessary
    tmb467
    By not inserting the Allen key sufficiently deep – probably due to crud in the hole
    Not by overtightening I’d hope
    teadrinker
    This so applies to me.
    trail_rat
    more than 6nm it would seem.
    I guess thomson specify 4nm torque value.
    Gunz
    I carefully torque everything around my bars and stem and I’ve only rounded off Thompson bolts which I don’t believe are the toughest out there. I tried cutting a slot in them and hammering in a Torx but eventually drilled the heads off (v. carefully).
    Get the Uberbike ones.
The topic ‘So the stem bolts in my Thomson stem are rounded?’ is closed to new replies.
