Viewing 26 posts - 1 through 26 (of 26 total)
  • So I have this big piece of stone…
  • mattrgee
    And I need to some how cut it up into equal pieces. It was until today part of a path in the back garden, but after lifting it I’ve realised I could use it to finish a wall I’m building assuming it can be cut up.
    Any bright ideas on a how IT geek / DIYer can chop this bad boy up?
    Angle grinder on either side and gently apply pressure.
    palmer77
    CountZero
    Hire a disc cutter? Stone masons use old carpentry saws, if you have one kicking around.
    Neil-F
    I’d be looking to go right through it with a Stihl Saw.
    monogramman
    Dynamite
    CaptainFlashheart
    Judo chop!
    drgalactus
    Tried a kung-fu chop?
    iBaa
    C4 🙂
    brakes
    can you not just score it with a grinder and then snap over something.
    Give a nice rough edge?
    banks
    Karate chop.
    Moses
    Sell it & buy some smaller pieces.
    York paving slabs are stupidly expensive, that’s a nice piece.
    sas78
    Would make a lovely seat on a stone bench that, in a sunny spot that’d heat up all day and be warm at night, like a natural storage heater! If you are in Edinburgh I’ll buy it from you!…
    crikey
    2 matches, then get a big lass to stand on it.
    kayak23
    Take it to a stone merchants/ masons. They’ll cut it up quick smart for a few bucks I expect.
    ptrockymountain
    Take it along to your local stone yard and swap it for the stone you need
    Easiest and cheapest way.
    MrNutt
    light a big fire beneath it then throw cold water on the top of it
    mike399
    As said above – Don’t chop it!
    b1galus
    scribe a line on it . cut into line with hammer and bolster on a bed of sand then repeat on reverse and then whack it
    wrightyson
    You won’t cut that with a bolster, it’ll just detonate into layers. Stihl saw and diamond disc as suggested above is the way!
    mattsccm
    Cut that! bloody sacrilage. Sell it for a fortune to some one who appreciates it
    mugsys_m8
    2nd pic shows a crack in it. By cutting it you might risk breaking it into smaller bits than you wanted.
    spooky_b329
    I just did this yesterday (with concrete)
    Stitch drill it will a masonry bit, several holes in a line maybe 5 inches apart, then a firm whack with a sledgehammer. Increase whacking effort until you are raising sledge as far above your head and in fear of your life. (my concrete was over 12 inches thick so suspect you won’t need too much effort, but the stitch drilling at least gives you a chance of it breaking in the right place)
    My goggles saved my eyes twice, and steel toecaps saved my toes once.
    wrightyson
    York stone is layered and at thickness will not appreciate the “whack” technique, trust me it’ll detonate bits everywhere!
    kayak23
    Encourage lines of ants to cross the stone by laying narrow trails of sugar across in the positions in which you want it cut.
    With patience, the footfall will erode the stone until such a time as it will easily fall into the required pieces.
    This process can be accelerated if you can ascertain what beetles like.
    slackalice
    My vote is with kayak! 😀
The topic ‘So I have this big piece of stone…’ is closed to new replies.
