Viewing 6 posts - 1 through 6 (of 6 total)
  • So how difficult to put new hoses into Shimano brakes?
  • TimP
    LBS cant help till next week, but have generally avoided doing anything to hydraulic brakes whenever possible and need to get my Xtracycle up and running ASAP
    haggis1978
    Really easy. Make sure you have the right hose fittings and a good set of cutters for cutting the hose and it’s a doddle. Have some oil and the kit for bleeding and it really is easy. By kit I mean small hose which fits over the bleed nipple and a suitable receptacle to feed that into then it’s normally an 8mm spanner and the oil feeder bottle. Having said that it I guess the bleed kit reqd depends on the generation of shimano brakes you have as I’m not sure what you need for the newest generation but in general it’s very easy
    Rorschach
    If you know how 1/10
    If you don’t but are’nt a moron 3/10
    If you’re an average stw’er 11/10.
    d45yth
    All the instructions are on the Shimano website.
    DrP
    Bring them across tonight, and I’ll do it for you!
    DrP
    Mister-P
    8mm spanner for the hose nuts, 7mm for the bleed nipples.
The topic ‘So how difficult to put new hoses into Shimano brakes?’ is closed to new replies.
