Viewing 40 posts - 1 through 40 (of 130 total)
  • So, how are we on tubes vs tubeless these days…
  • Kryton57
    I’m wondering whether to bother with the faff…?
    jedi
    i’ll never use tubes again. love tubeless but wont use the tape conversion kit only tubeless rims. thats part of why i got ride of my hope enduro wheels and bought some easton havens
    qwerty
    Tubless curious is as far as I’ve gone.
    Fresh Goods Friday 696: The Middling Edition
    Fresh Goods Friday 696: The Middlin...
    Latest Singletrack Videos
    Simon
    The faff of tubes is definitely not worth it.
    legend
    Likewise, been tubeless-curious for a while. Seems like a good idea, then every time I’m out with someone running tubeless we end up with a burping incident – “which doesn’t usually happen” of course
    jedi
    dont run low presures, just run the pressue you’d use with tubes and burping is a thing of the past (thats what i found)
    zbonty
    Well, its no longer the hot topic it once was since the choice of three different wheel sizes arrived
    I prefer a less ‘squirmy’ tyre so re-fitted tubes for summer
    endurokid
    Tubeless for me.
    After puncturing on nearly every stage at every enduro race this year I switched.
    No faff converting, had both done first time in a little over an hour.
    Well worth the cost.
    devash
    I don’t have a choice with my wheelset although I am fairly curious and when its time for new wheels and / or new bike I’ll be giving it a go.
    cardo
    Love tubeless, have run mine with ZTR rims and jollop for 2 years and they have been great and reliable on both bikes… Don’t really love standing around /helping fellow non tubeless riders who don’t get the tubeless thing whilst they mend another bloomin puncture…(Think Charlies singlespeed outing this year during the Gravel dash) With the right wheels and tyres its a doddle to do.
    Mackem
    UST tyres on UST rims are brilliant. They just work. Everything else is a faff and will fail/let you down eventually, – my experience anyway.
    warpcow
    I’ve been tubeless (ZTR rims and a mix of TLR and normal tyres) for a couple of years now. Judging by half the threads on here I’ve been very lucky though. Everything I’ve tried has gone up with a trackpump, the only burping I’ve had was with a shonky Schwalbe (proper tubeless one too), seen it seal plenty of punctures that would’ve burst a tube and the only proper blowout I’ve had destroyed the tyre so a tube would’ve also been done for. It takes maybe an extra 5-10mins to switch tyres for different conditions (which I only do maybe a couple of times a year), which I don’t see as too much considering the benefits. As above though, just because you can run crazy low pressures doesn’t mean you should.
    chvck
    I originally used XM819s and found them to be no less faff than any of my current (non-UST) rims other than initially taping them up. I use gorilla tape as the tape and it works better than tubeless tape IME. It used to be a faff but I’m getting the hang of it now and can usually get tyres to go up first time and stay up. I also don’t experience burping but I run the same pressure as I would with tubes.
    thisisnotaspoon
    +1
    Only ever burped one tyre, and that was a 6 year old maxxis high roller and I landed pretty sideways accross some rutts, it bent the wheel too! Still held enough air to get to the bottom of the hill.
    I’d say it’s reached the point where I get itrritated with people having to stop to fix punctured tubes, faff at home isn’t an excuse, you faff at home to make sure your gears work, your brakes work, your bearings aren’t worn so that you don’t have to faff on rides and hold them up. Why are tyres a special case? Once they’re up (which 95% of the time is a 5 minute job, as quick as tubes) that’s it for 6 months untill the sealent dries out and it becomes a game of puncture roulete Vs the ‘effort’ of putting another scoop in.
    Just wrap the inside of the rim with electrical tape. If at first it doesn’t seal, add more tape, a whole roll is only about 30g so you’re not adding any significant weight (compared to a 150g for a normal 26″ tube). Either cut the valve from an old innertube (with a locking collar, not one with a smooth shaft) and fit it tightly, or buy some tubeless valves (they’re almost as cheep as cheep tubes now). Pump it up with a trackpump (or handpump if you’re feeling masochistic) to chekc it steats (it doesn’t need to be airtight, the sealent will deal with small leaks). Deflate and pop it off again or add sealent through the valve and you’re done.
    I’ve done a bike in 20 minutes.
    The only combination that sruggles is non-tubeless tyres on non-tubeless rims, as long as either the rim or the tyre was made for it then it’ll work, and most of the time it works regardless I’d just avoid buying normal tyres if a bike ahs normal rims.
    njee20
    Tubeless all the way!
    GavinB
    Along with dropper posts, tubeless is on my list of ‘must haves’ for any new bike. I’ve not bought a compete bike for years, but if I was in the market for one, the lack of tubeless ready wheels would be a factor.
    FWIW I’ve run DTSwiss conversion kits which were close to lethal, with several blow outs at high speed on corners. Since then I’ve run various Mavic UST rims ranging from superlight XC ones, to 819 and 823 without issue, but found the 819 too narrow and 823 too heavy, so switched to Stans rims about 5-6 years back. I’ll never go back to using tubes.
    eshershore
    started using tubeless conversions years ago when I was working for Freeborn – the original importer of Stan’s No Tubes to the UK
    been using it ever since with great results and few if any problems
    key is good preparation and careful setup. I stopped using the over priced “rim strips” as I found they often leaked, and if you ruined the tire by slashing it open on some glass (requiring an inner tube to get home) you’d end up with a sealant covered rim strip and a naked rim bed which could easily puncture your tube!
    Found the best setup is to degrease the rim bed with iso alcohol, wrap several times in electrical tape, then twice with tubeless tape, prick a tiny hole for the valve, use a good tubeless valve core (the best have o-ring under lock ring) and be liberal with the sealant to ensure a good seal and long running life.
    If you do ruin the tire (this has happened 3 times in 5 years to me) you can just remove the valve core, and install an inner tube with the rim bed protected by the tape
    Used this setup on Mavic, Sun, Stan’s and Roval rims, found Specialized Control 2-Bliss tires the best for easy setup
    Still using Stan’s sealant as I found it the best. Worst was Specialized or Bontrager.
    nickjb
    That sounds like a lot of faff to me. Don’t think I’ve ever spent 5 mins inflating a tube, even with a rubbish mini pump and they don’t need changing every 6 months.
    mattjg
    tubeless, it’s a no-brainer
    it’s a bit of faff initially but you get to do the faff at home in the dry not by the trailside on a dark wet night ride
    amongst the crew I rode with 80% of the flats are experienced by the 20% still on tubes
    I pulled an inch long nail out of my rear tyre the other day, no idea how long it had been there, I never noticed picking it up
    Nobby
    What faff? The trying to change a tube whilst covered in cack in the p***ing rain?
    Running tubes these days is a very selfish thing to do as it causes your tubeless riding buddies to stand around in the cold/wet/muddy/snowy/icy conditions waiting for you to sort yourself out.
    mattjg
    on the other hand we have experienced more than one extra pint due to coming out of the pub and a tuber finding a flat, we leave them to it and go back in.
    ndthornton
    LUST UST tyres on standard DT Swiss rims working perfect for me. The combination of beefier sidewalls and low but not silly low pressures keeps them burp free. Goes up easy with the track pump also.
    I have them on the rear of both my bikes after getting sick of pinch flats. Still tubes on the front but will probably go UST when the tyres wear out – but front tyres never do !
    Nobby
    lol @ mattjg – I assume they also pay for the round (in view of the inconvenience & all that).
    richardthird
    No punctures last year using Panaracer Flataway tape with tubes. Easy to swap tyres over too.
    But being curious I switched to Bontrager Rhythm tubeless (UST compatible system) and the same tyres just feel so much better.
    It’s lighter so that’s a lot to do with it of course.
    mattjg
    no their fingers always seem to be too cold to open their wallets
    dunmail
    Re pressures: is it still weight (in stone) times 2 then +1 for rear, -1 for front? PSI of course.
    Yak
    Tubeless all the way for me. Never burped a tyre, never had punctures that didn’t seal….but I have slashed 2 tyres in the last 4 weeks though. Bad luck probably, but both were at really bad times. 1 was on a perfectly (up till that point) timed ride before a kids pick-up and the other was in a race. That 2nd slash was probably touch and go for a seal as it didn’t deflate immediately, just sprayed jizz out in a catherine wheel-style fashion, all over me, and no doubt the rider behind (apologies!) as I tried to ride it off. That lasted about 150m, then it was flat.
    Overall it’s better.
    mattjg
    there’s a formula on the Stans site for it, I use that reduced by a couple of psi
    Haze
    Sceptical when I switched a couple of back but definitely won me over, not flatted since.
    Considering it on the road bike when it’s new wheels time…
    dunmail
    mattjg: Ta, it’s here – http://www.notubes.com/help/tirepressure.aspx obviously in pounds as the US don’t use stones.
    Kryton57
    Maybe its just this pair of Nobby Nic SS TLR’s that have defeated me then. Must admit I’ve no problems with Ralphs or Bonty Mud X on AC’s or Crests, but I have to go through the 48hr tube-in/tube-out 2 x CO2 process with the TLRs which has just frustrated me.
    thisisnotaspoon
    It’s the same steps, you just fit a valve rather than a tube, and you don’t have to ‘faff’ with half inflating tubes, messing about trying not to pinch it as you get the tyre seated, etc, etc. OK that’s slightly pedantic, but it’s certainly less faff than installing a tube in a new bike, then having to do it again every few rides.
    And have you ever gone 6 months without puncturing a tube? That’s stretching credibility more than me saying tubeless isn’t more faff.
    ska-49
    Tubes for me at the moment.
    Tend to swap tyres and the cost/faff of changing them when tubless is hideous.
    I’ve not had a puncture in over 3000 miles.
    reggiegasket
    everything tubeless, including both roadies.
    Yak
    Some tyres are sods though. Easiest for me are specialized and bonty’s. Just get them off the packaging, put them on and inflate with a track pump. No need for washing up liquid, tubes in/out, ghetto coke bottles etc. Perfect.
    core
    Unless you use proper UST tyres and rims, I honestly wouldn’t bother.
    I converted Mavic 521’s with a stans kit, and tubeless ready butcher tyre – all as per instructions, various pressures, and I just could not stop the front burping, as soon as it got steep/rocky it just shat itself and nearly threw me off a good few times. Stuck a tube in, no worries since.
    Yak
    Now, those kits aren’t worth it. Tried them once with mavic 719s, and no joy. Swapped to tubeless ready rims and all fine since.
    ahwiles
    my group doesn’t seem to get many punctures, lots of smashed mechs, but not many punctures, certainly, all the annoying* punctures ‘we’ get are tubeless failures**. Those few ‘tubed’ punctures we get don’t seem to cause any hassle beyond stopping for a few minutes and a chat+snack+photo.
    a few of us have given up on tubeless as they found their valves get bunged up.
    (*those that mean you all stand around for ages, before eventually giving up and going home)
    (**small hole, jizz everywhere, reassurances that it’ll definitely seal in a moment)
    i’m not anti-tubeless, i even made my own ghetto-inflator-bomb, which is great fun to use, but i’ve got tubes in at the moment, and haven’t had a puncture for chuffing ages.
    Yak – Member
    i really will consider tubeless ready rims the next time i’ve got £300 lying around that i can spare for new wheels.
    Kryton57
    ahwiles – Member …you all stand around for ages, before eventually giving up and going home
    I think you have the wrong forum… 😯 😀
    medoramas
    I only have one bike, which is my commuter, MTB, sportive machine, etc… That means I change the tyres quite regularly. So tubes for me.
    Also I’m quite lucky with punctures, but when they happen – I’ve mastered the repair procedure, it’s a muscle memory thing now! LOL
    I’ve never had a pinch flat, and I run quite low pressures: 22-25 PSI front, 25-30 back (depending of the conditions and terrain).
    Funny thing is when I went for a ride on rocky tracks near Princetown in Dartmoor with two friends, who were both running tubeless, we had 3 punctures in between all of us. I didn’t have any. :mrgreen: Luckily I had 2 spare innertubes in my backpack… 🙄
The topic ‘So, how are we on tubes vs tubeless these days…’ is closed to new replies.
