- This topic has 161 replies, 63 voices, and was last updated 10 years ago by Northwind.
So Enve rims….
DougalFree Member
What benefit would lower spoke tensions give? Make the wheel less stiff?
There is Mavic research which shows that the spoke tension has no effect on the lateral (side-to-side) stiffness of a rim once it’s tight enough for the wheel not to de-tension.
What you do get with lower tensions is less radial stiffness, which gives you a bit more compliance and grip. Wheel suspension if you will. Of course the risk is going too low and having all the nipples loosen as load goes on and off them as the wheel rotates.
I’m not sure there is much benefit to lowering spoke tensions with an Enve rim, being as they are so stiff on their own. Over-tensioning a single spoke on an Enve build has much less effect on the trueness of a wheel as would an alloy wheel, thus it is easier to over tension one spoke and crack the nipple seat in the rim (seen this). If you’re building an Enve wheel, buy a spoke tensiometer to go along with it.
flangeFree MemberI LOVE how people bad mouth products because they’re expensive rather than actually riding a set to see if they’re any good.
If you don’t like them, don’t buy them. Don’t bitch about it because you simply can’t afford it…
geetee1972Free MemberI also love how people will happily spend a small fortune on frame and suspension components but baulk at spending an equivalent amount on their wheels when actually they can make almost as much difference in ride quality as the frame.
oscillatewildlyFree Membera lad i ride with occasionally has a regular riding buddy who has a set, first ride on them in the peak district, on the first descent of the day and the rim cracked!
it seems looking at other peoples reviews (and messiah) that they are not overly keen on rocks! im sure they are fine for racing on and probably if you dont live near rocks, but from the personal reviews ive read id be slightly wary (if i could afford them)….from what i gathered though hes having it replaced FOC anyways so its not really the end of the world….like someone else said stuff breaks, whether it be expensive or otherwise, carbon frames break, alloy frames break, alloy wheels break, and clearly carbon do too
i personally unlesss i won the lottery, wouldnt have a set of them for riding the peak district, but if i lived darrrn sarrrf way and was loaded id defo consider a set as i think theyd be fine elsewhere
honourablegeorgeFull MemberDougal – Member
Yeah – that’s what I was driving at. “These new carbon wheels are AMAZINGLY stiff. Now. How do we build them up so they’re not so bloody stiff?”
chief9000Free MemberCarbon rims are a bit odd in my opinion. In most cases spokes are used which apply point loads in a materials which does not like any point loads at all. If thickness is reduced in the rim, particularly where the spokes contact, you are likely to have a failure.
Maybe i misunderstood here but are these rims 750 notes each? This in my opinion is absolutely ridiculous and pushes the limits of what is acceptable. Bike companies seem to be taking the pi** more and more. 750 notes? The cost of the material in one of these things would be about 15 euros max, of course you have tooling (lets say about 1-4 euro if you make 10000 rims) them there is labour. In my opinion you are lucky to hit the 50 euro mark for production of these things.
messiahFree MemberDo you think that impact would have killed an alloy rim? I often used to find dings in my D521’s, but you could bend them back out with a pair of pliers.
davidtaylforth – When I dent an alloy rim I usually know I’ve done it. To be honest I thought at the time that I must have hit something hard and therefore it would have damaged any other rim. But I didn’t remember hitting anything just a loud “crack” like a gunshot. Since looking at the rim at home and reading of other failures on MTBR I’m now thinking it was a rim failure rather than an impact.
RorschachFree MemberNerd reading regarding spoke tension vs stiffness
http://sheldonbrown.com/rinard/wheel/index.htmgrumFree MemberYes they are relatively light, but you can get as light with alloy. The key difference is that the alloy wheels that are as light are nothing like as strong or, most notably, stiff.
Are they laterally stiff, but vertically compliant, and do they make the trail come alive?
Hmmm…..
You really do need to be riding your bike at the limit before you really start to feel their impact.
What is ‘the limit’ then? Is it somewhere in Surrey? 😛
I don’t need to ride them to find out that they’re ridiculously expensive for something that you’re going to repeatedly bash into rocks. Think many people here probably could afford them judging by some of the bikes people have – if they thought they were worth it.
excitable1Free Memberthey are not overly keen on rocks!
…. Lots of footage here to counter that one !
Tom_W1987Free MemberJust get some light bicycle rims or those new 40mm wide ones for a third of the price.
Mine have been great.
wreckerFree MemberProbably the best rider I know loves them. He swears blind that he’d have killed any other wheel by now (he’s had a few).
Price tag is waaaay too much for me, no matter how good they are. If I had a load of money to spend on new wheels, I’d be looking at those really wide Syntace ones.ratherbeintobagoFull MemberI wonder how robust/expensive the Stan’s carbon rims will be?
peachosFree MemberIt didn’t look like Bryceland’s rim failed, was watching it live, was more hub/spokes (all related, I suppose)
only saw the live images too, but thought it looked more than that. i could be wrong.
DH WC racers blowing up rims isnt really news though is it.
no, not really. but given he’s such a high profile rider & that they’re one of only a few teams singing about being on carbon rims i thought there would’ve been something said about it. but there was nothing.
just saying that the press embargo seemed a little fishy to me.
RHSno2Free MemberI got a pair. Frickin awesome, still straight as and not a chink. Set of Stan’s Flow after same period was busted, dented and wobbly.
They are stiff as and in rocky terrain its a bit of a shock but once you get used to it and just ride with strength and speed through sections its great. Makes the whole bike feel Super Tight.
My concept is they should last 3-5 years and equals the investment of other wheels sets.
They look awesome too 😉
juliansFree MemberI’ve ordered a set of the light bicycle AM rims, came to ~£250 inc shipping for 2 rims.
Not got them yet, but the reviews seem generally positive.
Would be interested to read of any direct and objective/scientific comparisons between the enve rims and the Light bicycle co AM rims, to see if theres a significant difference.
geetee1972Free MemberWhat is ‘the limit’ then? Is it somewhere in Surrey?
Surrey, Lakes, Peak, Verbier, Wales.
Take your prick. I’m pretty sure I’ve shown them enough speed over even the roughest ground to test them satisfactorily.
Reading the responses people fall into two categories.
Those that have them, love them and agree on the benefits I’ve outlined and those that don’t have them and think they are ridiculously expensive and can’t see how they are worth the added cost.
Which is fine.
Hob-NobFree MemberI’ve used a set of Havens, and a set of Enve’s. The latter not being mine.
People regularly talk about the stiffness, and combined with a carbon frame, I found them too stiff. On a long, off camber, rooty section they were noticeably harder to hold a high line on, as nothing flexed or moved.
As an aside point, when racing recently I got a high speed blowout on a rocky chute, tyre rolled off the rim etc. if I was running a carbon rim, it would have been wrecked,, it was that rough. There was a lot of chunks taken out of the Flow, but it still worked, and still does.
They are largely pointless IMO. I didn’t go any faster with them, and I found the bike rode better without, as a set of DT Swiss/Flows introduced a bit of wheel flex which made the bike feel nicer.
Still, if people want to buy them then who cares.
honourablegeorgeFull Membergeetee1972 – Member
Which is fine.
I’m more in the “they’d be a MASSIVE investment for me, and I’d want to be 1000% sure of their quality before I’d even consider it” camp. The other thing is the enormity of the price gap between them and their competitors – carbon wheels like Eashon Haven & Reynolds AM, etc are around 1K or less, compared to £750 for a rim, but the benefits are difficult to qunatify.
oscillatewildlyFree Memberexcitable1 – Member
Enve Wheels on Rocks !…. Lots of footage here to counter that one !
yeh i know what ya mean, but dont forget they are ‘good’ riders, the one guy i know of that has done it with enve rims isnt a ‘pro’ nor a slender person (just loaded!!!!) probably like a lot of riders with money on here 😉 , ie just plows through the rocks rather than picks lines etc etc, so im sure in the right hands they could live up to all the peak district has to offer, but i sometimes get lines wrong and have dinged numerous brands of wheels around the peaks, the only thing i think is if that was on a carbon wheel it wouldnt be a ding, it would be a crack
its just the price more so than anything, i just cant believe they are £1700 a wheelset, its just crazy, and dont get me wrong if i was minted id probably have a set as im a tart, but £1700 just for some wheels is a bit mental when you really think about it (especially just to get bashed, chipped, scratched etc around the rocky stuff)
that said dont think im moaning cos of the price, im probably alittle ENVE(ious) of people that can afford them, and i spend lots on bike stuff so im not one of the anti-bling/money brigade but even they are just too out of my league money wise, i do genuinely love seeing expensive bikes out and about, and the rims look mint in the flesh, and im sure the people who own them love them too
grumFree MemberThose that have them, love them and agree on the benefits I’ve outlined and those that don’t have them and think they are ridiculously expensive and can’t see how they are worth the added cost.
Not sure many people would splurge £1500 on a pair of rims then say that they are so so, or even crap. Quite a big investment in them (financial and otherwise).
amediasFree MemberMy concept is they should last 3-5 years and equals the investment of other wheels sets.
I should flippin hope they’d last that long!
Even if you were trashing Alu rims every 6 months (really? are you?) @£50 a rim if would take ~7 years to break even on one Enve rim.
Even in the long run, you’d need a decade out of one at least to even consider that argument, a lot of people still have 5-10 year old Alu rims, not to mention fashionable wheel size changes 😉
By all means extol their virtues from a technical and ride feel point of view, and if you can afford them then fair play to you, but there is no point in trying to pretend that they are the economical choice 🙂
davidtaylforthFree MemberDo you need tyres with really stiff (carbon?) sidewalls to be able to feel the benefits?
thisisnotaspoonFree MemberYeah – that’s what I was driving at. “These new carbon wheels are AMAZINGLY stiff. Now. How do we build them up so they’re not so bloody stiff?”
Different type of stiff as he said. Radialy the stiffness is given by the spokes in tension at the top of the wheel. You can’t crush a wheel radialy, that’s why arches are arch shaped! So A very siff rim lets you get huge side to side stiffness, but low enough spoke tension to allow it to deflect radialy.
Bit like low spoke count road wheels, they feel nice and comfortable, but are almost/just as stiff axialy as having a full 32/36 spokes.
I’m tempted by a set of lightbikes rims for Swinely, but worry about the Sticker Rock Garden.
Tried putting 100psi in your tyres if you’ve got more than 2.1″ suspension in the frame/fork ?
LosidanFree Member£750 per rim.
I have never owned a full bike which cost that much…
Does this mean I am below the poverty line?
NorthwindFull Membergrum – Member
An enve-sponsored rider I know who will remain nameless for obvious reasons got a set for free and says “They’re the best wheels I’ve ever had but you’d have to be insane to buy them”
sharkattackFull MemberAll this debating does nothing for me. I don’t like the way the handled themselves and manipulated the information in the wake of a very public failure. So I don’t want to give them my money.
thisisnotaspoonFree Member£750 per rim.
Yes, people like you are what’s stopping trail center cafes serving truffle sprinkled Chai Latte’s. B****** proles. :-p
But yea, on a serious note, bit my main MTB and Road bikes probably cost about that (I do have more expensive but less frequently used MTB’s though wasting space in the garrage!
atlazFree MemberAll this debating does nothing for me. I don’t like the way the handled themselves and manipulated the information in the wake of a very public failure. So I don’t want to give them my money.
That’s my thoughts too. Sounds like dodgy business and on top of that I think less of Pinkbike for not publishing their original review and then publishing Enve’s comments rather than just editing the review.
DanWFree MemberIn fairness to Enve I think the whole review situation reflects worse on Pinkbike than Enve. If you own a company and put something forward for review and the reviewers says the noticed a crack then continued to use the product out of curiosity then post up pictures of your product exploding how happy would you be? Yes a crack is bad news too but the warranty is in place to deal with these issues before things turn catastrophic.
Pinkbike is awfully biased and edited when it comes to certain brands. Take for example the whole Gwin getting poached to Specialized saga. Anything negative about Specialized got deleted from the comments and forums when I think Specialized pay quite a lot in advertising towards PB… same as any industry I guess.
With the Enve case on the other hand I think Enve probably wanted a fairer deal rather than having their exploded rims posted up when a lot of it could been avoided and was down to user error (i.e. riding a rim they knew was cracked)
DelFull Member^
‘i noticed yer rim was cracked mate, but a regular punter wouldn’t have so i decided i’d keep on ragging them and see what happened innt?’
clot. the guy’s entitled to take risks on his/her own kit but these parts were on loan. should have just been a warranty repair when the damage was noticed. mention that in the review by all means. that would have made a fair and unbiased review.
anyway. 750 flippin quid!!?!
that’s what i really wanted to say. 😀dirtyriderFree MemberHad a 26″ wheelset used for 18 months no issues,
Have full cockpit and rims on my tallboy which gets hammered and same on my road bike
Zero problems, so nothing to moan about
nicko74Full MemberBut I was disappointed to find out that, despite absolutely hammering the bike – at 10 tenths – down the final descent at Afan they just felt like wheels.
Damn them!!
😆ianvFree MemberZero problems, so nothing to moan about
Apart from the price/performance gain ratio.
£750 per rim takes the piss and any average rider who buys them needs their head examined.
boxfishFree MemberBuilt a set of Light-Bicycle rims on DT 240 hubs for 2/3 the price of 1 ENVE rim. They didn’t explode going down the Rangers Path on Saturday, and I don’t exactly ride with finesse. You pays your money and takes your choice!
solariderFree MemberI own a set of road 3.4s and off road XCs. Fantastic wheels, but the law of diminishing returns applies.
Are they ‘better’ than a £500 set of wheels? Yes. Well made, light, aero, good warranty, rebuildable, and have that bling factor which is nice if I am honest.
Are they 4 x ‘better’ than a £500 set of wheels? No.
davidtaylforthFree Member£750 per rim takes the piss and any average rider who buys them needs their head examined.
Er hang on, what planet are you on? Spending excessive amounts of money on bits and pieces is part of the hobby matey. I may not know how to ride properly, but I can reel off a load of twaddle about my expensive bike bits that’ll make it sounds like I know what Im on about.
The topic ‘So Enve rims….’ is closed to new replies.
