Viewing 4 posts - 1 through 4 (of 4 total)
  • SNMP library for Visual Basic?
  • footflaps
    Anyone use Excel / VB to set/get data via SNMP? If so, how?
    I want to do some basic network management / diagnostics from VB and dump the data into graphs in Excel. Currently I write shell scripts to get the data then parse it in Excel – only that's a bit tedious and disjointed.
    tragically1969
    Its a pain SNMP, only seems to be supported\used by weirdos locked away in an IT dungeon (Thats not you is it ?, sorry if it is !)
    We needed to integrate it into an industrial solution with Modbus TCP, sounds easy, it isn't.
    footflaps
    all I really want is snmpget and snmpset as VB commands….
    tragically1969
    Well doing a little bit of Google fu you might be struggling, it appears you can do it with some tweaking and fiddling and using various other tools:
    http://www.pcreview.co.uk/forums/thread-1412311.php
The topic ‘SNMP library for Visual Basic?’ is closed to new replies.
