Has anyone else been snapping axles in their Whyte rear hubs? I’ve done it at least once and sounds likely a second time, on a bike that is not ridden hard.
T130 C RS, (Eagle 12s, Whyte Hubs) bought around October 2016. May 2017 took bike in for a service and it turned out the rear axle on the hub had snapped. Apparently it was Alloy, and paid for a stronger (steel?) replacement from Whyte/distributor.
Probably ridden it <10 times since then due to work/injury/travel etc, and not riding hard/jumping etc.
Had problems with the chain getting wedged between cassette and spokes or between cassette and frame. Had a look at the bike while cleaning and the cassette moves inboard/outboard by 5mm+. Took it to Nirvana Cycles and they said it looks like axle snapped again, will call me back once workshop take a look at it.
Thankfully the rear triangle is alu, lots of nasty scratching/grinding from the chain there, probably would have been terminal on a carbon rear.
While I wait to hear back from Nirvana (not the shop I bought it from, moved house since), has anyone else had a problem with snapping axles? Any possible solutions?
