• This topic has 9 replies, 9 voices, and was last updated 6 years ago by Del.
Viewing 10 posts - 1 through 10 (of 10 total)
  • Snapped bolt on left SLX crank arm
  • Wally
    And then snapped the thread cutter in the hole I cut.
    Not going well.
    Where can I buy a new LH crank arm?
    cyclistm
    Wanted ad on here. Left hand arms are available but expensive. It’s probably cheaper to buy a chainset and eBay the driveside
    mikertroid
    JE James do them. My local LBS TY Cycles in Chipping Norton do too
    mikewsmith
    How old is it? Buy a crankset and you have some spare rings
    dc2.0
    I’ve just swapped the cranks on one of our bikes so have a 170mm SLX crankset (no chainrings) surplus to requirement. They’re M7000 – were used as 1x but I *think* the same chainset can also be used as 2x (certainly has the drillings for an inner chainring. Let me know if it’s of interest.
    coomber
    Is drilling the bolt out not an option?
    bigyinn
    Not if there’s a broken bit of easy out or tap in there its not!
    Tiger6791
    Think I’ve got an 10spd SLX crank in the garage, seem to remember at the time I got a deal on buying a whole new set instead of chainrings.
    What length / colour ?
    Just checked, yep 10spd, 175, in black/silver SLX
    Wally
    Tiger YHM
    Del
    I’d have a go with a drill from the other end if it were me.
The topic ‘Snapped bolt on left SLX crank arm’ is closed to new replies.
