• This topic has 4 replies, 3 voices, and was last updated 9 years ago by ton.
Viewing 5 posts - 1 through 5 (of 5 total)
  • smaller rings, direct mount front mech question?
  • ton
    my parkwood has a direct mount front mech. it runs a 26/38 combo up front. I want to swap if for a 22/32 combo.
    can I do this with the direct front mech? there is no way to move the mech up and down the seatpost.
    ton
    nobody? 😐
    wwaswas
    most direct mount mechs have a cm or two of movement built into the mount point don’t they?
    robware
    There is some vertical adjustment available. Or there should be, at least. There is on mine. Just loosen off the bolt holding it on and adjust accordingly.
    ton
    thanks for that, I never realised…..cheers.
The topic ‘smaller rings, direct mount front mech question?’ is closed to new replies.
