Sick to death of my SRAM mechs. The latest jams itself into the top ring and won't come down. I think the spring is buggered. It's rubbish.
Always bought expensife shifters (seems to be what affects the shift)
Any disadvantage over the SLX? Its 16g weight difference i believe?
Pair of XTR shifters and a SLX mech?
This is fairly standard for SRAM stuff, released too early and with poor quality control. I went through 2 X9 rear mechs under warranty and the last one was doing exactly what you say. The reason is that the bushings are pressed in too tight at the factory and can be remedied. Have you tried sending it back under warranty?
I have Sram X0 on my downhill rig and that works faultlessly but I have given up on SRAM for mountain adventures and gone back to shimano. I bought a shadow XT mech brand new from a certain shop in the UK for just over £30 and used some old XT shifters from 2004 I had in the spares bin. Utterly reliable, faultless shifting and far better not worrying about jammed gears halfway up a mountain.
In the past few years I have had problems and warranty returns on the following SRAM products:
Rock Shox Pike
Rock Shox Boxxer Team 08
Rock Shock Boxxer Team 10 (returned twice)
Rock Shox Vivid rear shock (fell apart once, returned 3 times)
Avid Elixir CR brakes (3 sets on warranty replaecment)
SRAM X9 rear mech (limit screws worked loose during decent)
SRAM X9 rear mech (bushings too tight)
Don't get me wrong the SRAM stuff once properly fixed has been very good but why should we have to put up with things that don't work out of the box? SAM UK are very good with warranty issues but it takes them up to 6 weeks to turn it around as they are so busy.
