Hi guys and girls,
Brought a set of used SLX Brakes off here a while back. When i got them, i understood that the rear brake had no fluid in and would obviously need a bleed. I’ve bled brakes before so i didn’t see this as an issue.
Anyway, I’ve now had two attempts at bleeding with no success. I cannot get fluid to push through into the lever, and if i try push down through the lever, it leaks out from under the ‘SLX’ lever lid.
I’ve got a shimano bleed kit as well as a funnel. I’ve tried bleeding from the caliper upwards, and also from the lever with no luck. I then removed the hose from the lever and pushed fluid up from the caliper and it came out of the end of the hose no problem, so my issue must be with the lever.
I’ve stripped down the lever body and gave it a good wipe down. I’ve used an old piece of brake hose with the olive attached and tried to blow air through the system but i cannot so it must be blocked in between the hose and the hole which fluid leaves the reservoir. If i fill the lever up from the top and then pull the brake lever, nothing happens, no fluid moves out of the system.
Has anyone got any ideas on how to unblock this? Has anyone had this issue before. I’ve now wasted about 100ml of mineral oil as i’ve tried bleeding it so many times. As i have said, the caliper and hose seem to be functioning normally, and i therefore must have a blockage in the lever.
Thanks!
