they were the first set of brakes i have bled but, by the secone brake it was a doddle.
have the old deore and would say there is even more modulation. lever is soft and the full power comes on at the end of the stroke. you can adjust the sitting position of the lever but found that the lack of bite point adjustment isn’t an issue. remove wheel and pads. open top cap of lever. squeeze lever to encourage pistons out a little. top up with oil. close everyting off and refit.
found it tightened up the braking – shorter lever stroke.
will swap the pads over a i got rear covered in oil and replaced with some no-name brand which seem better so will use them on the front.
+1…….don’t think you can really go wrong with any of the shimano brakes.
+1 for formula too. nice design whereas shimano is all very functional. italian vs japanese design, think nissan and alfa but on the other hand you have italian vs japanese engineering…… not heard bad things about formula though and said to have very good heat resistance.
