I’ve got a nice small Olympus E620, and I fancy the pancake 50mm equivalent lens which makes the whole thing small enough to go into a chunky compact case and easily fit in a camelbak or similar for biking and outdoor expeditions:
…costing me £120-£150 depending on where I buy it.
The question is, would you rather have that, an SLR with a fixed focal length 50mm lens open to as much water/dirt as one would encounter on a ride, or a ruggedised compact costing about the same, with water and dirt resistance, zoom capability and small enough to fit in a pocket?
Not sure a 50mm is all that handy for bikey shots.
But personally I wouldn’t want one of those compacts. They are good for giving to the kids or for snaps, but they have tiny lenses and poor controls for any “real” photography.
(before sfb shows up, by “real” I mean anything where the photographer is hoping to take something more than a simple snap)
Hi I would go for the SLR but with a short to medium zoom having said that I have a Pentax K7 and a selection of lenses the wife has a Panasonic TZ 9 which is a TZ 10 without the GPS when I go out on the bike I take the Panasonic.
It’s a choice between those two. I already have the SLR and a 28-80mm equivalent, which is fine, but it’s big. The point being I can spend £120 on making my SLR small enough for biking duties, or the same (or more to be honest) on a compact.
i’m using a Panasonic TZ10 atm, only drawback i can find so far is it only has a set 2 sec or 10 sec timer, which is a bit short to run back to your bike for solo “on the bike” shots
i did have a canon ixus110is which was excellent but i’ll be honest i wasn’t that careful withit and dust and dirt got in the lens zoom mechanism and borked it, if you are careful (and for example don’t use muddy gloves then shove cam in your pocket) it’s great
i have a dslr and a olympus tough. The olympus comes on bike rides with me. Turns out I like riding more than taking photos, so if there’s an opportunity to do one or the other, camera normally stays in the bag 🙂
Its a shame the tough range don’t have a bit more in the way of manual controls. My perfect backup camera would be something with the controls of a decent powershot, but the strength of an olympus. I can’t be the only one??
I’d be after a compact. I have a decent SLR and wouldn’t take it mountain biking as 1. it’s to big and bulky and 2. I would be worried about stacking it and smashing it to bits.
With a compact neither of these things are a problem.
Seriouslly considering a Samung EX-1 or A Pnasonic LX-5. Manual control, sharp lenses and fit in your pocket – check the reviews. They do most everything I’d want a DSLR to do, but don’t need expensive lenses like a PEN/GF.
Your Olympus should take the old OM lenses? there’s lots of them about second hand.
I’ve looked for OM lenses. The adapter is expensive, and you end up not being able to use autofocus. Bit of a pain for every day photography, but since I’m looking out for a macro lens I thought I’d investigate. Turns out the adapter is almost the same price as the entry level macro lens I’d buy anyway, and the OM macro lenses are another few hundred on top.
I’ve got a Canon S90 compact which has a decent size sensor, can be run fully manual and shoots RAW – I’d hoped that it’d do the job nearly as well as my SLR.
Unfortunately so far I’ve been a little disappointed.
there are other ruggedised compacts, but very few that are properly waterproofed. My olympus comes surfing with me, so that (for me) is a necessary requirement.
Posted 13 years ago
Viewing 21 posts - 1 through 21 (of 21 total)
The topic ‘SLR v Compact’ is closed to new replies.
