I had this regularly when swapping UST tyres about.
LBS advised:
Use muck off (or similar) to lubricate rim/tyre interface when inflating – also use of Co2 cartridge makes for better seal. Over inflate, up to as much as 50/60psi to ensure tyre bead clicks onto rim.
Use wheel milk or similar to help seal tyres, once inflated, role tyre round in the air (holding wheel level/horizontal) letting the sealant work its way around the tyre bead/where it joins the rim, the sealant I was told helps seal the tyre and make it airtight.
Having followed the above process each time I change tyres no more air loss. Hope this works for you. Also make sure Stans rim tape is flush and actually sticking to the rim all the way round, on my Stans flow rims I had to re do the tape after the first one developed an air bubble near the valve hole which leaked a slow amount of air over a few days.
