Need to re-build a retaining wall that will be about 50cm high and will need some steps built in the middle.
At that height will the sleepers alone be enough to create the retaining wall if laid horizontally with either the longest width flat, or will it need reinforcing with stakes, back-filled with dry concrete mix or a course of concrete blocks?
I estimate that the cost of sleepers for the whole lot will be about £500, which I guess is far cheaper than stone / brickwork, is that fair?
Will the sleepers be any good as steps? they’ll need to be accessible in all weathers so was thinking that the steps would be better matching the material used in the patio and path in the garden that the steps link (Indian Sandstone).
How well will the sleepers last? Thinking of new, brown Tantone(?) sleepers so I’m guessing several decades?
