Minimal width as it works by the pressure melting a thin layer of snow and the runner then glides on the water. Kids trying to use bodyboards were obviously unaware of this!
I made my runners from 1" x 1.5" wood (running on the 1" surface) and simply melted wax over them, warmed it with blow torch and skimmed with off cut of wood. Worked pretty well but after 2hrs use will require a little more wax 🙂
One downfall mine had was only 1.5" ground clerance, has been revised now but was ok on smooth slofes but not in powder!
Might see about some copper strip to glue on there 🙂
SSP
