I currently run a VanRC with a 350lb x 2.37″ spring fitted (thanks to Loco) on a Remedy
I understand that the 350lb is the spring rate (and that’s fine)
and the 2.37″ is the amount of travel.
The whole spring is 12cm long (4.72″)
Now… if I want to fit a different spring, such as a ti one, what specs are valid/equivalent? I want the same spring rate (350lb) as I’m happy with that.
– will, say a 350×2.5 be okay?
– are all springs 12cm long?
(the shock body could handle a longer spring)
– would a 2.5 actually result in more travel? (maybe a daft question….)
– would a 2.5 change how the bike rode (sag, feel, geo etc.)?
– are all ti springs of the same spec, the ‘same’?
If there is an online resource that would be handy.
