Sheldon,
I got myself a set of SC-32s and converted to 29er (with home made wooden blocks). After a bit of fettling (the online tuning guide is spot on) they’re sweet. Experienced a bit of an oil leak from one leg, but after opening it up, found a bit of grass in seal. Changed the oil in the damper to 15w to slow the rebound and compression. Trails in Sweden are super sweet just now – like FoD, but with loads of exposed granite, which I’m loving. Give us a shout if you’ve over in Stockholm and we can show you around.
Andy R – the forks are great, but to get the best out of them you need to be prepared to fettle a bit. This involves no major work, but some of it is a bit scary the first time. eg, I’ve never taken a damper to pieces before. Maverick designed them with user service and maintenance in mind – which is sweet, but means you need to get dirty to tune them perfect.
