I’ve only ever had one bike, currently thats a Carbon 456. I use this for everything, including commuting to work which is 10-15 miles each way, depending on which way i decide to go (normally 10m to work, 15m home). It running 36T front and 11-32 rear cassette (1×9). Tends to be downhill mostly into work but into the wind, and uphill on the way home. Not too many big hills really, but i guess i’m used to them now.
Anyway i want to sort out a cheap commuter bike that i can lock up outside the gym and not worry about too much, I’ve got a frame sorted, some rigid OnOne forks, 26inch mtb wheels (currently have a commuter set and on offroad set of wheels that i change over at the weekends).
Basically i need help deciding on firstly which tensioner to go for, and what tooth sprockets to start with.
As i’m trying to make this as cheap as possible to start with, i’ve been looking at a Truvativ IsoFlow Single Kurbel which is 42T which i can get for £16+ £7 for a BB plus postage, So was thinking a 20T rear might be a good starter point (superstar set £10).
The tensioner i was looking at was again from superstar, this: http://superstar.tibolts.co.uk/product_info.php?cPath=58&products_id=269
Thought a fixed tension would be better than something that works off a spring like a normal rear mech, (surely i’d also need a front ring device too running a sprung loaded tensioner?)
If anyone could other advice on these or point out better equipment for similar money, i’d really appreciate it.
Thanks
