Viewing 8 posts - 1 through 8 (of 8 total)
  • Singlespeed my Inbred 456
  • dasnut
    and make it into a low maintenance commuter.
    What parts do I need (its a standard dropout 456 old skool blue one, with a pro2 rear hub)
    what is the best gear ratio?
    dasnut
    MussEd
    You’ll need a SS spacer kit – I’ve got a DMR felly right here for £10 posted to your door?
    Depends on how flat your commute is for ratio…
    dasnut
    commute is a big chunk of tow path, but a couple of road climbs (short but steepish)
    do I need a new chain? (half link job) or do I use a tensioner?
    please reserve that kit for me Mussed once I fully understand all this jiggery pokery then I may well have it….
    ski
    I would go with a chain tensioner
    You might need smaller chain ring bolts.
    You should be fine with the original chain though
    Is your middle ring a 32T, if so might be worth going up a bit to 38-42t with a 16t rear.
    mudsux
    i have
    bontrager singlespeed cranks with 38t unramped chainring, with bashguard. 170mm arms. Square taper. also have the 68mm sq.taper BB.
    i also have Hope rear cassette spacer set in polished silver.
    and new Groove armada rear cogs in 16t and 17t.
    if interested my email is in my profile.
    takisawa2
    36 x 16 sounds just right for you.
    32 x 16 makes you look like a hamster on the road.
    dasnut
    Think my front is a 34 (34\24 setup at the moment) – how does 34×16 sound?
    I have a bashguard which will be staying so I won’t need different chainring bolts
    can I do without a tensioner if I use a half link?
    mudsux what does the hope spacer kit consist of?
    mudsux
    probably not. it’s so much pfaff to get the magic ratio – when really what you’re seeking is a suitable ratio.
The topic ‘Singlespeed my Inbred 456’ is closed to new replies.
