Stoner
Well that’s it. Im officially old enough that I forget shit now.
😆 Well I was going to say something similar but my equality training at the place I am contracting at these days pointed out that age jokes are not a laughing matter… 😀
Ti is generally quite good at resisting wear and has a high shear strength so freehub bodies are actually one place it is good. Except I would avoid using a Ti lock ring to a Ti freehub without a good anti-seize.
verses – Member
The lock ring was nice and tight.
I think the play was mostly the cog shifting back and forward in the groove it had carved in the freehub.
Although there may also have been a fraction of a mm side to side play (it’s hard to say with the forward/backward play being there too). I’ve found a slightly wider spacer to replace one of the ones that was on there just in case.
Does sound like even though the lock ring was tight it wasnt fully clamping the sprocket. Shouldn’t be any play at all. Add a thin shim like spacer somewhere in the stack and see how it feels.
