Judging by the title you are probably thinking this man is insane, surely?
You may be partially right but here is the dilemma.
I love single speed. We all know the pros and cons that ss can bring. It frees your mind to concentrate on the surroundings without your subconscious constantly worrying about the mechanical shortcomings of changing gear.
You only concentrate purely on power and braking. How hard do I pedal or how hard do I brake. Its that simple. Great design always comes through simplicity and its this simple approach which makes ss truly a liberating experience.
I’m by no means a zealot. I was lured into ss through a snapped chain. My rear derailleur was shot and my chain snapped which meant I could no longer ride. So instead of buying a new one I removed a few links and placed a very very taught chain around a smallish cog. I rode like this for several days and If im going to be perfectly honest with you after a day or two I was hooked!
The strangest thing is initially you reach for the gear shifter as you normally would but realise its no longer there because you removed it. Very strange feeling that took around a week to break the habit.
Once the honeymoon period was over and my legs got stronger It was insanely addictive and incerdibly quiet both mechanically and mentally. There is little thought process going on upstairs when you are ssing it.
Finally for all those who say single speed is not flexible enough I say BS. The only, I repeat, the only time you crave for more gears is on the flat. Hills rarely become a problem. Your legs get so adjusted you change your mindset and attack the shit out of everything. Hills are not a problem unless they are super vertical in which case it makes sense to get off the bike and push-but whilst doing so you have the best opportunity to stretch lots of additional muscle groups which you wouldn’t ever do spinning. Infact its much better for you to run up the hill with the bike. Single speed can be and usually in my case is faster. Especially uphill!!!
HERE COMES THE QUESTION.
Could people vote on the best off-road ss hubs giving the pros and cons of each and their invaluable usage experience.
I want a quiet single speed hub but it seems they are too pricey. True Precision Stealth Hubs come to mind buy they are shit by all accounts.
I’m losing sleep researching and I’m seriously considering just getting a 2012 model Shimano XT m788 hub with spacer kit which would be quiet and cheap and very efficient. Any opinions would literally make me sane person once again. Yours truly. Mr Crazy head.(Temporary title)
