The superstar kit is better IMO as you have alot of thin spaces so can get the chain line spot on to quieten things down and prevent the chain skipping off. And it’s cheaper.
http://superstar.tibolts.co.uk/product_info.php?cPath=58&products_id=265
If you have a alu. free hub body, then use a wide base sprocket to prevent/reduce the sprocket cutting into the free hub
http://superstar.tibolts.co.uk/product_info.php?cPath=58&products_id=267
Also, assuming you are using the frame you have gears on at the moment so it has normal vertical dropouts, you will need some means of maintaining chain tension. You can bodge it with a rear mech with the limit screw adjusted to suit, or with a bit of gear cable clamped through the mech.
Or a quicker easier way is to use a tensioner, this works great for me
http://superstar.tibolts.co.uk/product_info.php?cPath=58&products_id=268
EDIT – if you don’t already have just one chainring installed, you will need some short chainring bolts
http://www.evanscycles.com/products/id/single-chain-ring-bolts-ec006126
