Viewing 10 posts - 1 through 10 (of 10 total)
  • Simple excel question
  • wonnyj
    I’ve got a sheet with several columns and about 1500 rows. I’m using autofilter to do basic analysis on the data.
    If I autofilter search for a certain text input, say “south”, is there a command that will let me count the number of entries of “south”?
    jam-bo
    yes
    wonnyj
    and what is it o’wise one?
    psychle
    highlight the cells and on the bottom right of the screen there’s a wee little box that you can right click on (should say NUM I think), right click on this and choose which one you want it to report (in your case it’d be Count Nums).
    molgrips
    Er look in the help under functions.
    It’s something like COUNT maybe, I forget.
    DrRSwank
    You could put a column of “1” all the way down and just sum this. The sum corrects depending on the autofilter.
    wonnyj
    Ah lovely, that’ll do.
    I’m a bit allergic to excel help function.
    wonnyj
    I did the “1” count already, but thought there must be a better way
    Nick
    countif
    McHamish
    =COUNTIF(A1:A2,south)
    Change A1:A2 to the range.
The topic ‘Simple excel question’ is closed to new replies.
