Since no-one else has done it yet…
103
Signals warn and inform other road users, including pedestrians (see ‘Signals to other road users’), of your intended actions. You should always
give clear signals in plenty of time, having checked it is not misleading to signal at that time
use them to advise other road users before changing course or direction, stopping or moving off
cancel them after use
make sure your signals will not confuse others. If, for instance, you want to stop after a side road, do not signal until you are passing the road. If you signal earlier it may give the impression that you intend to turn into the road. Your brake lights will warn traffic behind you that you are slowing down
use an arm signal to emphasise or reinforce your signal if necessary. Remember that signalling does not give you priority.
104
You should also
watch out for signals given by other road users and proceed only when you are satisfied that it is safe
be aware that an indicator on another vehicle may not have been cancelled.
