Viewing 7 posts - 1 through 7 (of 7 total)
  • Showing laptop display on TV – help please
  • WorldClassAccident
    Is there anyway of getting my laptop to display on a normal HDTV? I want to watch iPlayer stuff on the TV instead of the laptop.
    mikey-simmo
    S video output on the laptop? bout all i can suggest unless you’ve a DV camera with an S video output to act as a converter.
    nickjb
    What do you mean by ‘normal’ HDTV? The last two I bought both had a VGA socket. I geuss yours doesn’t or you wouldn’t be asking.
    Some laptops have TV out. Usually S video, which is usually a small round, yellow, 4 pin socket.
    Failing that you can get a convertor, either usb or vga to TV out. PC world sell them or they are much cheaper on-line.
    WorldClassAccident
    I have an external monitor socket, a mic socket, a headphones socket, a network socket and some USBs. It is a Lenovo R61i if that helps.
    It also has s-video out so use that.
    spooky_b329
    Use a VGA lead between the external monitor socket and the VGA in on the TV. Same type of socket as the external monitor one on your lappy.
    I had to mess around a little and set my laptop up so it treated the TV (external monitor) as its primary display otherwise when I shut the lid the TV went blank.
    You’ll also want a 3.5mm stereo jack to phono connections for your sound. iPlayer (standard quality) is perfectly watchable on a 32″ screen 🙂
    spooky_b329
    Oh, had to mess around with the resolution for the primary display as well…I found 1280×768 gave me a full widescreen image without stretching/black bars (I think – can’t check that as gf has control of the remote at the moment 😉 )
The topic ‘Showing laptop display on TV – help please’ is closed to new replies.
