Just ordered some so installation experiences would be appreciated too pls.
Thanks guys n gals
Thanks guys n gals
I found the crown race a tight fit. A kindly STWer gave me a top tip - hold the race in some pliers and heat it with a lighter to make it slightly bigger, then drop it on the steerer. Slide the stem over the steerer and use it to tap the race flush against the crown with a mallet.
When you saw off the steerer, think very carefully about leaving a little excess in case you want to sell it on to someone with a taller headtube.
I also had problems fitting the star nut which I did using an old handlebar and mallet, breaking the first one. The second one went in OK.
The fork works well, being very active, perhaps slightly hyperactive which folk complain about. But the high speed compression/lockout and rebound adjusters do actually have a useful range of settings.
Have fun!
i didnt have a problem with the crown race, mine was a split one so just slid on with finger pressure.
got a gravity dropper on there now, and yes, i will get round to lopping some of the stearer off at some point
There you go, mine are the 100-140 Coil u-turn with a firm spring fitted.
Great forks.
Had Sektor RL's on the BFE for a few weeks, bit too 'active'..
Now have Lyriks, also coil and I'm much happier.....
Here's mine
Photo 19-08-2011 20 06 00 by NJF70, on Flickr
Cheers muckers - should get mine next week to fit to a Pitch Pro - can't wait to bang ell out of em...
Will post a pic up once fitted - replacing Pikes so got some work to do:)
Cheers again;)
Nice rides btw
Nicksar - what is that frame?
It looks shagged
It looks shagged
Coyly smoking a cigarette with glowing cheeks?
Mine had to go back to Sram 3 times with a faulty lockout, sorted now and happy with the fork but was pissed off when the lockout stopped working after 200meters of tarmac riding after the second time they were fixed.
Giant Trance X2 by 555Andi, on Flickr
150mm Air version.
Jambon it's a KHS XCT 536
Here is my pitch with the standard sektors it came with ..........
eventually going to replace with with something else as they have no lock out etc and are quite bouncy and yet i cant get full travel from them either??
Andituk, whats the trance like with 150s?
No pics at the moment but have them on my blue pig, they do the job well. I'd definitely buy them again.
Here's my Trance X4 with Sektor Coil U-Turns (110-150mm, 15mm maxle)
Great for climbing on 110mm and superb for descending on 150mm!!
Since this photo it's now got a Reverb 2012 post and some XT pedals - must stop spending...
Old bike:
This was it's first ride... I have Coil Sektors and have found them to be just right..first time using Rockshox. I did end up using a HOPE head Doctor as the Star fangled nut thingy wouldn't tighten enough and constantly had play in the headset.. Otherwise spot on
You must log in to post.
