I'm with Edric 64 – I never adjust my saddle height so I don't have this problem…saying that, my carbon seatpost that came with the biek has a tendency to slip so I'll be junking it for an alloy post soon.
If you do move your saddle up and down often how about a very large inner tube and 2 jubilee clips? You set the clips at either end of adjustment – 1 on the frame below the clamp, locking the inner tube in position there, fill with a bit of grease and then clamp the inner tube just above the point where the post is in it's lowest position – you can then adjust the post to your heart's content, but also keep the crud out as the inner tube will allow some movement – not the cleanest but certainly a sealed system compared to not using it…jubilee clips are about 10p each and you can get some nice slim ones that would look too Heath Robinson.
You need a right baggy inner tube though – maybe a 3.5" diameter one so there is enough slack to allow it to move up and down…
