It depends on what you want to achieve. Right up until this weekend, I’ve been running a 65mm, 10 degree rise stem on my Wolf ridge (with Wotans and 760mm bars). I’ve not quite gelled with the setup, the bike seems to lack feel and feedback. I managed to compensate for the lack of grip by fitting a soft compound front tyre, but there was still little or no dialogue going on between my hands and the contact patch at the front, even though it seemed to be gripping okay.
Anyway, I invested in a 50mm zero degree rise stem. Fifteen millimetres isn’t much, but in moving the bars further toward the centre of gravity, I seem to be able to lean the bike through the corners more effectively. The front end feels like it has more “bite”, plus the rear tyre doesn’t spit traction quite as readily because I’m able to aid traction with my body weight more effectively.
If you are going that short with your stem, I’d suggest that you go up a size on the bars to 750/760mm at least…you won’t cut into breathing room too much. Besides, you can always cut down a bar that’s too wide.
