We have a 7.2m long motorhome and it’s possible the council will introduce permit parking with a max vehicle length of 6.5m.
Drive is 6.5m long to the front of the garage (which is a decent length, used for storing bikes and crap and has a large kitchen behind it). Garage is single storey, attached to house on one side, wooden ply roof with a ashfelt cover, brick and block walls. square front with up and over door. The drive is about 40cm wider than the motorhome where it woudl go past the side of the house.
So we have a number of choices;
1) replace the motorhome. Woudl rather not – we like the one we have, would lose money changing etc
2) put motorhome in storage – cost is significant annually on the south coast, we’d use it less if we had to drive for half an hour+ to get to it.
3) Make the garage a bit shorter and put the motorhome on the drive.
Looking ahow the things’ built just working back a couple of joists , knocking the front end and a metre of sidewall down then rebuilding with the existing RSJ across the entrance, reuse door, tie into to existign brickwork and the side of the house etc.
Does this sound like a big job?
Should it be possible to just ‘roll back’ the existing roof covering and refit to the new front end?
Do I need building control?
I’d probably knock a couple of metres off so there’s a bit of space in case we replace it with a longer model.
