Viewing 9 posts - 1 through 9 (of 9 total)
  • Short cage mech and 40t
  • eulach
    Has anyone managed to squeeze a zee mech onto a 40t cassette adapter and get it working?
    orangeman5
    Friend has and working fine… 😀
    oli31
    yep mine works fine too. Chain can be a little slack in smallest gear so you need to be accurate with chain length and line
    mcnultycop
    Yup.
    spev
    Yea mine is working fine, didn’t need to use the replacement ‘b’ screw either
    eulach
    Thank you ^. I’ll have something to keep my busy for a bit this weekend when it’s raining cats and dogs. What about 42t? Just out of interest.
    matthew_h
    I’ve got a SS cage on my XTR rear mech on my Tallboy and it is working absolutely fine with the Hope 40t. I double checked the chain length and dropped the shock to make sure it would not be a problem at full compression but it all works spot on.
    domderbyshire
    I use a Zee FR mech with a Hope T-Rex 40t on my Trance with no problems.
    torquil
    Oneup say 40th is fine as long as your frame has less than 25mm of chain growth.
The topic ‘Short cage mech and 40t’ is closed to new replies.
