You've got the Pope on speed dial hav'nt you
No good to me...I'm an atheist.
Bike Forum
Shoddy workmanship??where do i stand
Posted 5 months ago #
The best thing about having cronic OCD regarding bikes is I could never have lived with the play/creaking that must have been coming from that mess without investigating before it was terminal!
Posted 5 months ago # -
It never ceases to make me chuckle/cry when bikes come in for something minor (usually a bit of cable stretch) and inconsequential to be fixed......and completely ignore all the major league important stuff that is actually wrong with it (usually blown shocks and/or seized/failed bearings).
And then blame the messenger,because 'it was'nt like that when I brought it in'
33mm hole saw. That's the trick - it'll shift almost any stuck cup. Or if it's a steel axle in a steel cup, I weld the axle to the cup, clamp the axle in the vice, and rotate the entire bike.
There are very few things you can't fix with an oxyacetylene torch - or make much, much worse
I'm not allowed 'firey' things anymore......after 'the incident'
convert - Member
But if it was anything like mine, there was no undue noise or creaking. Like I said, I managed to remove all the alloy from the threads in the frame, the new BB went in smoothly,. but tightly, and it's been fine since.
The best thing about having cronic OCD regarding bikes is I could never have lived with the play/creaking that must have been coming from that mess without investigating before it was terminal!Posted 5 months ago # -
Oh oh....you're THAT Bencooper!!!Can I borrow your sclumpf bb tool and 45degree cutter after crimbo?I'll give you a bell tommorrow
Sure, no worries - as long as you give it back, unlike another bike shop who will remain unnamed. Swines
Reply
You must log in to post.
