• This topic is empty.
Viewing 1 post (of 1 total)
  • Shock eyelet and mount sizing – 15mm eyelet?
  • glasgowdan
    Hi, I’m in the process of sending my BOS back to get a broken switch fixed, and trying to borrow a shock in the meantime.
    The current shock mounts are 22x8mm front, and the rear doesn’t have any eyelet bushings, bolts straight onto the mounting bolt, at 12.7mm wide x 15mm diameter.
    Does anyone know if standard shocks have 15mm eyelet diameter, without eyelet bushings inserted?
    Thanks
The topic ‘Shock eyelet and mount sizing – 15mm eyelet?’ is closed to new replies.
