Presuming you are akin to your username….the five is awful with the standard can. The reducer kit should sort out the midstroke as it did with mine when i had it.
With regard to the rebound…..there must be a fault with the shock. Is it making a slurping noise for the first part of the travel? In which case it might be cavitated – also happened to mine and fixed by mojo – which from vague memory meant there wasn’t any rebound damping in the first part of the travel.
If its in warranty send it back to mojo. They kindly sorted the aircan volume out when fixing the cavitation. Next time it went back under warranty they also sorted the rebound tune out to my personal pref for gratis.
If its out of warranty send it to either loco or tf tuned with the latter doing the Push tune. I used tf as they were around at the time and it made a world of difference.
