Viewing 40 posts - 1 through 40 (of 42 total)
  • Shitmano chain
  • rob-jackson
    broke 3 times in 2 miles today 🙁
    its less than 100 miles old – side plates just popped off when pedaling, not even changing gear!!
    epicyclo
    Probably made by SRAM under contract… 🙂
    druidh
    Bad workman etc. etc. etc.
    rob-jackson
    how so druidh?
    eth3er
    The consensus is that Shimano chains are better than sram. As you’ll hear more about broken Sram chains than you will about Shimano.
    Druidh means you repaired the chain, are hamfisted, have wonky legs and can’t ride and so you are blaming Shimano. That’s what you meant Druidh isn’t it?
    Kahurangi
    Good job no one has ever heard of a broken SRAM, Sachs, KCM or other brand of chain. It’s a wonder they’re still in business what with all the failures!
    Three_Fish
    Plates that break as a result of shifting under load do not generally do so at the time of the damage. They’re bent by being dragged across the teeth on the sprockets, then snap when they’re pulled straight again – either in one go (pedalling up a steep climb, for example) or ever time from normal riding. How long it takes for the damaged link/plates to be in the right place (ie between the front and back gears) to have sufficient force applied is completely unpredictable. You could ride for hours before snapping the chain, or it could happen in the next revolution.
    I’d say that most chains break from being incorrectly joined or from rider-inflicted damage, with the latter being the most common.
    Garry_Lager
    Did you repair it with a powerlink or do it old style with a chain tool? If its the latter, its quite easy to do a sub-optimal job at the trailside and have it break again.
    I broke a chain today as well – first break for years. I was heaving on it like a fool though up a steepish pitch.
    rob-jackson
    powerlink (it now has 4 sets of powerlinks in it)
    bassspine
    @eth3er hmm round here the concensus is that SRAM and KMC are both more reliable than Shimano. Two different consencii?
    this.
    cynic-al
    “Round here the concensus is that
    Shimano . “
    really? what numbers?….or is that “well I’ve seen a few posts about broken shimano chains”
    My favourite chain-thread FAIL was a guy who reckoned shimano chains were worse than SRAM because his shimano chain had broken further away from home than his SRAM one, leaving him with a longer walk 😛
    chickenman
    Only ever had problems with Shimano ones; Sram ones have been great. That goes for my riding buddies too!
    bassspine
    well, my concensus is from the three bike shops I’ve worked in as a mechanic over the last twelve years….but whatever
    cynic-al
    fair enough you implied it was from posts here.
    my years in bike shops showed few problems with shimano.
    twohats
    You know that KMC make Shimano chains don’t you?
    Broken chain are more often than not, down to poor joining technique.
    Been in and around the bike trade for many years and can also agree with the above quote.
    leffeboy
    Sure you don’t have a bent tooth on a chain wheel or somewhere else that is slowly causing the plates to splay?
    Or could just be a one off bad chain as that isn’t normal behaviour
    rob-jackson
    poor joining technique – it was joined in teh shimano factory ffs
    bassspine
    1) in any mass-produced item there will be occasional manufacturing problems.
    2)to be honest, they’re all pretty good
    3)the problems used to be with joining, this is why shimano invented snap off rivets and everyone else does quicklink variants
    4)sachs and SRAM, KMC and shimano, all the same machinery
    5)the most common cause of chain breaks is poor shifting. if the same person has multiple chains break, I usually suspect their shifting…
    6)I have broken two chains ever, one was manufacture, one was poor rivetting by me (on a single speed 🙄 d’oh )
    7) happy days
    cynic-al
    noted and agreed 😎
    twohats
    cruzheckler
    You have factory support on your rides!
    Northwind
    “twohats – Member
    You know that KMC make Shimano chains don’t you?”
    Not all- and to Shimano’s spec not their own.
    Jeffus
    Only ever snapped two chains SRAM 991 SRAM 970 my usual chain is SHimano XTR they just wear out for me and no other problems.
    Reluctant
    Shimano chains for me – anything else is just plain wrong. Never broken one; fit ’em, wear ’em out, replace ’em.
    If i ever do break one, i won’t diss Shimano on the internet. I’ll put it down to rogue freakery and recall all the fantastic rides i’ve had with Shimano chains – god bless ’em.
    johnners
    Did you fit the chain the right way round?
    rob-jackson
    9 speed chains are not specific direction. If it was my shifting technique it would have happened before to the same extent, i have snapped one chain before and that WAS my fault.
    ltheisinger
    I’m with you CH – I love SRAM, never a fail for me…. where as Shimano, couldn’t go on a ride without a failure!
    twohats
    True, but there is a joining technique recommended by Shimano that sort of makes them direction specific.
    http://techdocs.shimano.com/media/techdocs/content/cycle/SI/Chain/SI_0450H_001/SI-0450H-002_en_du_ge_fr_v1_m56577569830686193.pdf
    crankbreaker
    Snapped countless Shimano and SRAM chains, moved to Wipperman and it’s still going strong. Plus the Wipperman is the only powerlink type setup that actually works in my experience.
    Blower
    Was with cruzheckler yesterday while the chain snapped once while he was on the road,and once on flat off road section..
    in my experience over the years ive never got on with shimano chains miself.
    always had sedis-sachs-sram.
    uwe-r
    Hmm… I was just about to buy this combo>
    Sram PG970 cassette
    http://www.chainreactioncycles.com/Models.aspx?ModelID=5213
    and
    Shimano XTR chain
    http://www.chainreactioncycles.com/Models.aspx?ModelID=1018
    Now im not sure? Help
    cynic-al
    uwe-r it will be fine if you john it right.
    Chain failures are rare for any brand.
    uwe-r
    I have always just use a Sram link.
    I tried the Shimano pin thing once and butchered a link.
    sam42
    connex chain ftw
    uwe-r
    Three_Fish
    KMC X9.93. Don’t be put off by it’s lack of expensiveness.
    _tom_
    I’ve never had any luck with Shimano or SRAM chains. Always breaking sometimes more than once per ride, load of shite. I now stick to KMC x9, used to use their 510HX on bmx as well and never had any problems. I find the powerlink better than the SRAM which was unreasonably stiff to put on/remove.
    rob-jackson
    It broke where it had been joined in the factory not where I had fixed it. It was initially joined with a powerlink and snapped.on the opposite side of the chain
    Three_Fish
    So you (maybe) got a dud chain – no need to piss your pants. You aren’t any more or any less likely to get a wrong ‘un if you buy a different brand, so just get one that you think is pretty and carry on. It’s very, very rare for a chain to break due to a manufacturing defect.
    _tom_
    I’ve had 3 shimano “dud” chains. That’s enough for me to not bother with em again. Should’ve learned after the 2nd one snapped really.
    69er
    eth3er – Member
    Not here you wont!
    What a load of tosh[/i](it is a sunday) 😉 . I’ve been running SRAM chains for years. They’re simple to fit, bullet proof, you can take them off with your bare hads to clean etc, and represent good value. I’ve had no problems on the geared bike or s/s. And I ‘tested’ the durability of a Powerlink by running it on 5 or 6 repacement chains on the s/s which sees lots of winter mud.
    Shi*mano have failed me on three occaisions, and even a female riding partner who is quite err…. steady, has has Shimano chain split side plates. And don’t even mention the stupid pin thing.
    My experiences match the OP. Time for a change!
The topic ‘Shitmano chain’ is closed to new replies.
