so come on how do you stop your shirts having deodorant marks, underarm stains???
Been ironing and several shirts have marks under the arm, pretty unsightly and meaning new shirts, and all on the right pit???
so how do you prevent it …so just to make clear
me arm pit hair cut back regularly…shower daily and after gym
deodorant using spray on, invisible mark stuff left to dry
all shirts worn for work one day changed when back home then washed
I believe this is a common problem, in my experience. Have you tried changing deodorant to a roll-on, ie Mitcham? Also make sure it’s completely dry before you put on your shirt.
Edit: are you using soap or shower gel? May be worth trying something different?
Just to add that my ex had this problem and he wore shirts every day. I don’t know whether it’s to do with the amount one sweats or a bit of dehydration. Understand perfectly what you’re saying though.
sounds like the arms are the offending item here, cut them off and go ozzie rules style….women may actually also want to smell you dressed in this manner…….or may think your a bum, it could go either way chap
The spray type deodrant is to blame (apparently), the stuff that lasts x hundred hours has a lot of extra stuff in it that causes the staining (and other nasty things)…change to a roll on and it should be fine.
1. Wear a t shirt under the shirt.
2. Make sure the anti perspiration/deodorant is dry before putting your shirt on. I dry my underarms in the morning with a hair dryer before putting my shirt on – works a treat.
To get rid of the marks on shirt, liberally spray with white vinegar (about 50p bottle) and rub in a bit before washing. Works brilliantly for that type of stain. It also has a multitude of other uses, as with all vinegars.
I use this stuff called odaban, you put it on at night, then shower in the morning. Use it once a week or so. Follow the instructions or it can be uncomfortable.
from my OP
and turn the sleeves inside out before washing
do that already but good point
lemon and vinegar ..off now to the kitchen
You trim your armpit hair?
Why
original because
a) thought long hairs may stop the drying process and hold the roll on the hairs not the skin
b) actually it is bloody unsightly
really intresting this as it is usually just my right pit excessively sweating
a) dehydration….got me thinking but usually have 2 to 3 litres of water per day and more often with an elctro lyte
B) exercise or such and I sweat like Zidane…………really should be a tester for base layers, at work not really a identifiable sweaty bloke, apart from one arm pit????
Can I just point out that all that white shizzle is designed to block up your pores and screw with your sweating system.
My suggestions:
3) Don’t eat stinky processed crap. I don’t mean stop eating curry, just McDonalds etc.
2) Wash armpits with some sort of detergent – ie shower gel or Fairy if you’re cheap/hard like me. This removes all the fat, whereas soap doesn’t – [check the scum on the bath for proof].
3) A variation on this:
4) All the above may be of limited use as everyone’s body is different and what do I know I may be a stinky git 😀
Footnote – Being paranoid about being a bit stinky is natural – place the blame squarely on the genius marketing people who invented the early adverts for ?deodorant?toothpaste? using the strapline “Even your best friend won’t tell you”. Scared the shit outta EVERYONE ever since.
Try that in Africa with temp in the high 30s and humidity in the 80s! Sweat runs down your back just standing still in a pair of shorts let alone a shirt…
Change deodorant. Try a roll on (any brand), then try another one if that fails to work. Spray on never worked for me.
Spot treat your shirt pits before washing as mentioned. Perhaps try a different wash cycle (warmer, cooler) or a different detergent.
Prize awarded to gofasterstripes for the anti-Golden Arches mention on a thread about sweating. Truly middle class angst there.
I keep one of those water spray bottles with diluted washing liquid in it by the wash bin.
Quick spray on the pits (of the shirt) before it goes in the wash bin, soaks in nicely before the wash and clears everything away that normally gets missed in the wash.
Just to clarify – I’m not saying eating McD’s will make you smell, but surely the problem is: I am using deodorant because I am afraid of smelling bad. The deodorant is staining my shirts – how do I prevent this.
Now, the way I look at it, you could, if you want to reduce these marks, do it by using less deodorant, or switching to a less powerful type with less smell-absorbing white powder. You could also help prevent smells coming out of you by eating less smelly food.
In my experience with people who I can smell, many of them smell of greasy meaty food, often a bit like hamburgers.
I have also noticed a strong correlation between people who I know* have an unhealthy diet [majoring in pre prepared or processed food] and those persons that smell quite a bit like that food.
As a rational person, I understand that in many cases this is not the case, most people who eat processed food do not immediately smell like a branch of their favorite eatery, but – in an effort to answer the OP’s question I mention this as a possible answer.
YMMV
*As I eat a [annoyingly, expensive] diet based largely on freshly-cooked veg and unprocessed food and devoid of meat save the occasional fish-dish I take quite an interest in what other people eat. No, I don’t tell them what to eat, before you ask.
All this is in an effort to help the OP with his Q 🙂
Footnote – My Girlfriend suggests 100% cotton shirts, as you will then sweat less, requiring less armpit spray.
Other footnote – I find it interesting that you choose to make assumptions about my class, interest in the concept of “class”, or membership of class I may or may not have been born into and may or may not choose to identify-with all based on my liking for fresh, unprocessed food.
