my Zee felt stretched to its limit even with just the 36T on a 1X system..
swapped to a medium XT which immediately felt loads better..
i’ve also experimented with chainline at the front too..
first moving the BB spacers to the non drive side.. which helped loads with the indexing in the lower gears
and i’ve now moved them back and got some 3.2mm chainring bolt spacers which moved the chainline inboard and put the crank back in the right place.
(the 30t chainring im running also needed some extra little crank hole spacers making to remove the play from the chainring bolts in the crank arm)
now got pretty much perfect indexing..
after that i have added a one up 42t, shimano 16t and a rad cage..
which all went on with no further issues. 🙂
