Also wind the free stroke screw out as far as you can, plus have the reach adjuster wound out so the levers are as far from the bar as possible.
This lets you get a little more oil in the reservoir.
Never though about the reach adjuster giving extra oil for the reservoir, good idea.
With that generation of XT I found that using the yellow block whilst bleeding gave more lever throw than I liked. I just took a file to the block to make it slightly narrower.
I think this is my exact problem. I thought about it and I think the problem with the block is that when braking that pads compress thinner than the block, so that is why is feels different.
I usually find a dominant piston is the problem
I have never heard of this issue. how do I go about confirming that it is a dominant piston and solving it? When I look at the pads closely while squeezing the lever, the pads looks like they compress together and evenly.
Thanks for all the help!
