I had a clutch mech fitted back in December, it worked fine for a few rides then developed a strange issue. It would shift into bigger cogs fine, but if I tried to click the gear lever to release tension and move down into a smaller cog, nothing would happen. After shifting I had to reach down and pull up manually on the gear cable where it runs along the downtube to get it to shift into the right cog (needless to say after a few rides around Afan this got pretty tedious).
Took it back to the bike shop who said the cable had seized up due to poor conditions and replaced inner/outers and reindexed the gears. Everything was fine again until 2 rides and then the problem recurred..
Any suggestions? Everything used to work fine until this clutch mech went on, which is why I’m thinking it’s the problem. Could it be a shifter/cable problem? According to the bike shop the shifter was fine.
