Get your LBS to order you a couple of those. They fit perfectly. Screw in with allen key, so you don't need to carry an extra split pin in your kit should you need to change pads on the trail.
Just swapped mine out
What if you loose* that when your changing them ?
* only logical reason i can think of for needing to carry another split pin with you On the trail to change pads
You must log in to post.
