It’s quite easy.
Before starting – the levers should be left horizontal and the calliper so must remain lower than the upper end of hose.
1. Remove pads and squeeze lever and install the yellow bleeding block – this retains the most fluid
2. Undo the retaining nut at the lever and slide it down
3. Trim hose to required length and remove the old olive if it has slipped down the hose
4. Install new olive over the hose then barb. Then install the barb. Use a little mineral oil to make sliding the barb in easier. You can also safety widen relieve the end of the hose to make it easier still
5. Insert newly barbed end into the lever and tighten nut into lever compressing the olive.
