Thanks for the confirmation of this – it still doesn't help with what freehub to order online that will fit this hub. The importer didn't seem to know either:
Their reply
Unfortunately we do not range the particular Shimano freehub body you require. It appears to be a Shimano Original Equipment part spec'd by the bicycle manufacturer directly from Shimano.
We would suggest contacting your nearest bicycle brand dealer, they should be able to help you locate a replacement freehub for your bike.
but with the part number you suggested I've found someone that sells it – many thanks!
Shimano non series freehub
