Afternoon all. Anyone running the new Road hydraulic shimano disc brakes? How do you find the stopping power?
I am 12 and a half stone and find the front requires a lot of force to stop quickly. Almost all the power in my fingers (on drops).
I have changed the pads to race matrix and have also tried swapping my XTs over from my other bike. Again even swapped rotors over to ensure contamination is not an issue.
Lever is firm with around 10 speed mm of travel before bite. Have reverse bled the brake just to be sure.
Apart from trying a 180 rotor I am not so sure I can get them better. This is my first Road bike and am used to XT / slx and deore mtb braking power.
I can easily lock the front wheel up and lift the back wheel on all my other bikes… But the feel of the road brakes is totally different (and maybe normal?)
I am worried that I am having to use so much force on the lever to get decent braking power…. Is it possible to damage the piston or seals in the lever?
And yes all pads have been bed in properly as per uber / shimano guidelines.
Thanks all
