Viewing 5 posts - 1 through 5 (of 5 total)
  • Shimano disc brake caliper mounts
  • ken_shields
    I need a front 180mm IS caliper mount and IIRC a rear 160mm mount is the same as a 180mm front mount.
    Am I right?
    K
    coatesy
    yes, 20mm difference front to rear.
    robbo1234biking
    Ive got a rear 160 is to post mount adaptor that will fit a Shimano 160 on the rear if you want it for a couple of quid?
    ken_shields
    I have enough brackets thanks robbo I just wasn't sure if they fitted and didn't want to take things to bits if it wasn't going to work
    Thanks chaps
    robbo1234biking
    No probs – It isnt worth doing a classifieds ad for one disc mount bracket so thought it might be useful to you!
The topic ‘Shimano disc brake caliper mounts’ is closed to new replies.
