Hi all,
I know there’s a few threads touching this, but old thread revivals never work…
At the moment, I run SRAM 1×10. N/W ring, X9 Type 2 rear mech, Force shifters, LH gutted.
I’ve had problems with the mechanical discs, so thinking of binning them and going hydro.
I was going to get CX1, but the price is huge compared to the Shimano RS685 (like £200ish more for SRAM!!!)
Thing is, I love the 1×10. I like the lack of rattles, weight saving, and the lack of clogged up front mechs.
If I go shimano, there’s no 1×11 perfect solution, so it seems the end result is RS685 brifters and discs & 6800 rear mech
My questions are:
* does the LH shifter flap or rattle around if not in use?
* when they say you need medium cage for >28t sprockets, I presume that’s under the assumption of a double chainset, and therefore short cage is fine, even for 11-32 or 34 or even 36 cassette?
* It looks like you can increase the spring tension – anyone bothering with that?
Thanks,
Leon
