I’ve bled my XT M785 brakes and they go to the bar. I’ve followed the epic bleed solutions guide perfectly a couple of times now to no avail.
I bled them with the block in and assumed the issue may be that the pads are worn so the pistons don’t want resetting right in and rebled with pads and wheels in (risky I know) but the same happens. They’re 18 months old and have had alot of use, are they dead?
I can pump the lever a few times and they feel fine if not perfect but leave them 5 minutes and they go back to the bar again, I know they’re supposed to adjust with pad wear, does this take a bit of time after a bleed?
Really can’t afford new brakes at the moment..
