I found a big difference between deore and SLX BBs… In everyday use I reckon SLX last about twice as long, maybe a little less. (otoh I destroyed a deore one in a single day on the dh bike! Obvious wrong part for the job is obvious)
Hope is better… But you can get about 4-5 SLXs for the price of a Hope, and Hope isn’t 4 times better. Depends how you feel about disposable parts though. Shimano are essentially unservicable, you can remove the plastic cap and clean/grease the bearings but it’s a hassle and you’re relatively likely to damage the cap. Oh, also Shimano are pretty sensitive to overtightening, whereas Hope aren’t.
Another good alternative is the Gusset EXT24- lasts a little longer than XT and is slightly more servicable, the bearings are easily accessed if you want to clean them. But also, very easy to replace the bearings in, unlike Shimano where it’s (I think intentionally) slightly fiddly. Comes in pretty colours and costs not too much.
Having said all this, Shimano tend to die from seizing up rather than going slack so I’d check it all first to make sure it’s not just loose 😉
