The Tri Align system Avid employ confuses matters as their calipers are designed to run with it.
As they use 185mm adaptors, it makes sense to assume removing the washers would space the caliper at 180.
You need to make the mistake of trying it to find out most of the time though, coz Who reads manuals?
Who has the time?
That’s what the LBS is for.
And for a nominal charge and maybe some cake, they’ll just do the job competently (if they’re any good) while you’re at work.
And your weekend will be trouble free riding.
*edit- Appauling grammar corrected. Frankly, I’m ashamed. My apologies if you read this before the correction.
